02 r6 parts, Mi
02 r6 parts, Mi
02 Frame with CLEAN TITLE 8k miles not bent or cracked at all - make offers
starter 85
front wheel not perfect
front fender red 40
cables - throttle, choke, clutch - 15 each
throttle tube and grip 15
both front calipers 80
rear brake caliper and line and master cylinder 50
fuel pump 40
front axle 10
rear axle 10
airbox 20
oil pan 50
oil pump with chain 30
oil pickup filter and pipes 20
I also have a cylinder head that has a crack in the side but is repairable, all the valves in it are good 100
ignition coils (4) 40 a set
heal gaurds 20
shift lever 30
sprocket cover 10
rear sprocket with hub attached 40
front sprocket 30
cush drives for rear sprocket 5
horn 10
plastic frame inserts 25
make offers, thanks.
starter 85
front fender red 40
fuel pump 40
front axle 10
rear axle 10
airbox 20
oil pan 50
heal gaurds 20
shift lever 30
sprocket cover 10
front sprocket 30
horn 10
speedjunkies
01-14-2013 05:55 PM
