cbr1000rr parts
cbr1000rr parts
I have been parting out a black 2007 cbr1000rr. Most of these parts fit either 04-07 or 06-07 models. I've sold about a third of the bike but, I still have the motor, right and left handle bars (clip ons), tail section, full exhaust/ header, some plastics, sub frame, swing arm, gas tank (not dented), airbox, throttle bodies, ecu, pegs, shifter, rear shock, rear brake, master brake cyl, steering stabilizer/dampener, regulator rectifier, complete wiring harness, radiator w/ fan and some other misc items that I'm probably forgetting to put on here. I also have a spare frame that I bought a while back without a title incase I bent the original frame I had. Since this one doesn't have a title I'll take just about anything for it, completely straight. Everything is is great condition and nothing is bent or harmed. Only had 2700 miles on it. Too many pictures to put on here, but if you are interested in a piece(s) email me or text/call me at cebbeler7@gmail.com and 317.362.5550 and i'll give you more pictures and we can work out a price from there. I live about 15 minutes out of Indianapolis, IN. Thank you!
Once again
email: cebbeler7@gmail.com
phone: 317.362.5550
Once again
phone: 317.362.5550
Re: cbr1000rr parts
UPDATE:
I have sold quite a bit but still have plenty of stuff left:
-subframe
-left handle bar (clip on with master brake cyl)
-Regulator Rectifier
-Airbox
-Kickstand
-Gas Tank (not dented)
-plastic piece that goes over subframe and holds battery
-chain gaurd
-front left peg
-heat shield
-rear rotor
-rear brake
-HESD steering dampener
-Rear sprocket
-Rear shock
-Header
-Ignition and key
-Throttle Bodies
-Motor
-ECU
-Wiring Harness
-extra frame (black, straight, no title so please stop asking if i have found it and no it's not stolen. I got it from a friend who had gotten it from a junk yard. I wanted it in case i ever wanted to stretch it or if i had bent my original frame, so thats the story on that)
I believe that is everything I have for the motorcycle If you need anything please let me know ASAP.
-subframe
-Airbox
-Kickstand
-chain gaurd
-front left peg
-heat shield
-rear rotor
-rear brake
-Rear sprocket
-Rear shock
-Header
-Ignition and key
-Throttle Bodies
-Motor
-ECU
-Wiring Harness
speedjunkies
01-14-2013 05:55 PM
