Hayabusa Parts
Hayabusa Parts
Busa Cylinder block off stock bore hayabusa. Excellent condition.$280
Busa clutch master cylinder with clutch lever $30
Busa rear master cylinder $20
Busa rear brake lever $20
Busa gear shift lever $20
Busa front wheel $90
Busa overflow bottles (3)
Busa front brake calipers (4)
'02 Busa gas tank (excellent condition) $200
'00 Busa gas tank (fair condition) $145
Busa cush drive hub (2) $25
Busa pistons/rods $10 ea.
Busa valve cover (3) $20
Busa injectors (4) $15 ea.
00 Busa injector harness $20
'02 Busa T-bodies (broken) $20--SOLD
Busa horn (3) $10
Busa steering stabilizers (3) $10
Busa clutch cover (some scratches) $45
'02 Busa starter drive gears $60
Busa left foot peg assembly with shifter $45
Busa clutch slave cylinder $25---SOLD
Busa clutch hubs inner and outer (3) $60 ea
Busa oilpan (1) $70----SOLD
Busa rear brake caliper $40
Busa starter relays (2) $25
Busa rear rotor $40
Busa lower steering stem $25
'00 Busa left side controls $25
'00 Busa right side controls $25
'00 Busa wiring harness (some cut plugs) $60
Busa rectifier (3) $25
'00 Busa rear sets left and right-right has broken mount $35 ea
Busa steel subframe (2) $65
Busa left and right turnsignals (2 sets) $15 ea.
Busa crank rotor (1) $85
'04 Busa rear brake caliper $45
ignition coils (many) $10 ea.
Email me at direct @ trc691100@aol.com if you want a response
** Also if you paypal me PLEASE type in the parts you have bought in the subject so I do not get peoples parts mixed up. Thank You
Brand new Ti-force full system in the un opened box for hayabusa 99-07
$600 Email me DIRECT at trc691100@aol.com if you want a response
Busa horn (3) $10
Busa rear rotor $40
speedjunkies
01-14-2013 05:55 PM
