GSXR parts 00-08
GSXR parts 00-08
GSXR parts 00-08, F4I fairings Parts as followed: 00-03 GSXR 750 01-02 1000 parts.
1. (2) 750 Swingarms $25.00.
2. (1) 03 rear fairing, in mint shape, it does have two cuts on the side for a 12 o clock bar, but never stunted with $60.
3. (1) 600 Swingarms $25.00.
4. (1) 03 GSXR 750 Complete left shifter setup, $65.
5. (1) 03 GSXR 750 stock damper in mint shape, $20.
6. (1) 03 GSXR 750 lower triple tree missing one tab, but good shape, $50.
7. (1) rear passenger pegs in good shape painted black $20.
8. (1) Right handlebar clip on $45.
9. (1) GSXR 750 Rear shock set with shock $35.
10. (1) 03 GSXR 750 Complete right brake setup, $65.
11. (2) GSXR 750 Rear brake setups $45.
12. (1) Complete left handlebar setup, $65.
13. (2) Rectifier $60.
14. (3) Rear axle bolt and nut $10.
15. (1) Stock exhaust $35.
16. (3) ECu, CDI brains $80.
17. (4) Front axle bolt and nut $15.
04-05 GSXR 600 750 parts
1. (1) 05 GSXR 750 tail fairing, almost mint, only missing the tab that goes under the driver seat. No damage to fairing except for that, painted blue to match my bike $140.00.
2. (1) Stock exhaust $35.
3. (1) rear passenger pegs in good shape painted black $20.
4. (3) 05 GSXR 750 Rear shock set with shock $55.
5. (1) gas tank, tank was mint until it drop and hit the ground in my garage, some light scratches, but no holes stunting, $85.
6. (1) 04 GSXR 750 tail fairing, has light scratches, only missing the tab that goes under the driver seat. $80.00.
7. (2) 04 GSXR 750 ECU, CDI in perfect shape $150.
8. (1) 04 GSXR 600 rectifier in perfect shape $60.
9. (1) Rear rim in perfect shape with tire $185.
10. (1) Uncut Undertail tray $10.
11. (1) Rear axle bolt and nut $10.
12. (1) Left handlebar clip on, $45.
13. (1) 05 GSXR 750 forks mint $300.
14. (4) Rear Calipers $40.
15. (1) Left handlebar clip on, $45.
16. (1) Right handlebar switches, $25.
17. (4) swingarm in good shape $65 .
18. (2) 04 GSXR 750 Complete wiring harness, $100.
19. (1) Complete right handlebar setup $75.
20. (1) Right handlebar clip on, $45.
21. (1) Complete shifter rear set up, $75.
22. (1) Complete brake rear set up, $75.
GSXR 06 - 07 750/600 and 05-08 1000
1. (1) 07 GSXR 750 lower triple tree missing one tab, good shape $45.
2. (1) 07 GSXR 750 forks set $300.
3. (1) 07 GSXR 750 lower subframe section mint $100
4. (1) 07 GSXR 750 Front rotors in perfect shape $150.
5. (1) 07 GSXR 750 rear rotor in perfect shape $45.
6. (1) 07 GSXR 750
7. (1) 07 GSXR 750 lower triple tree in perfect shape $95.
8. (1) 07 GSXR 750 Front rim in perfect shape $300 w/out tire and $375 w/tire.
9. (1) 07 GSXR 1000 front fender, slight crack from over tighten, but nothing serious $50.
10. (1) 07 GSXR 1000 stock headers with converter $65.
11. (1) 07 GSXR 1000 lower subframe section $120
12. (1) 07 GSXR 1000 Complete shifter rearset $85
13. (1) 07 GSXR 1000 Carbon fiber slip on exhaust $210, mint.
14. (1) 07 GSXR 1000 passenger black pegs $70.
15. (1) 07 GSXR 1000 micron carbon fiber slip on exhaust with stock headers $230, mint.
16. (1) 07 GSXR 1000 right clip on $70.
17. (1) 07 GSXR 1000 left clip on $70
18. (1) 07 GSXR 1000 lock set, have 2 keys, ignition and gas tank. The only thing missing is the tank lock, $90
19. (1) 07 GSXR 1000 fuel pump, $70.
20. (1) 07 GSXR 1000 Rectifier, $60.
21. (1) 07 GSXR 1000 stock damper in mint shape, $50.
22. (1) 07 GSXR 1000 rear rim $160
23. (1) 07 GSXR 1000 rear rotor $50
24. (1) 07 GSXR 1000 complete brake rear setup $85.
Located in Hawaii
PM me or email me at Stefanenyce808@gmail.com .. Thanks,
6. (1) 07 GSXR 750
Located in Hawaii
Re: GSXR parts 00-08
Still got the Tail section for the 01-03 GSXR 750? if so can you plx e-mail pics. JesseFugett@bellsouth.net
Sorry frames are sold. I should be picking up some 750 clean title bikes this week. I know one of them has a bent neck, but not sure how bad. Let me know. Thanks,
