954 parts
954 parts
CDI w/ harness
CLEAN title frame
Clutch cable
Cracked guages (will verify they work today)
Rear seat w/ stunt hole.(never used)
Swingarm w/ rear hugger
Beat Tank w/ fuel pump
almost minty tank (see pic)
Rear shock
Rear brake assy w/ peg No rearset
Rear wheel
right rear passenger peg and bracket
Sprocket and drive
starter
Have a headlight too. And a right side fairing. Will post pics of those later.
And that other chunk on the last pic. I'm tired. And can't remember what it's called
CLEAN title frame
Clutch cable
Rear shock
Rear wheel
Sprocket and drive
starter
Re: 954 parts
What kind of shape is the back half of the plastic case for the gauges?
How much for the swing arm and rear hugger? Any damage on the swingarm or hugger?
Shoot me a PM I don't get on here that much.
Re: 954 parts
Man, it's not like that at all. Ask Cincyskillz. I ship quick and communicate good. I hadn't seen any pms. And only had a sec to log on.
As far as guages, I'll snap the rear pic today. Along with the side fairing and headlight. They will be up before the super bowl. Sorry guys. The headlight has 2 missing tabs I believe. The right side is gray and black. Or silver and black. Whatever that scheme is you call it.
Re: 954 parts
Ok, I had the guages. My boy took em to sell em without tellin me. That fell through. He says the only damage is the 2 clear pieces on the front. The guages work perfectly he says and the back is mint. I have his 954 at my shop. As soon as he brings me those guages back after the super bowl, I will plug them in to his bike to verify. He says they work fine and have 13,xxx miles on them. Here are the pics I said I would get...
The fairing has a small crack that you may not be able to see. But I'll post the pic with the fairing pic. The headlight is missing 3 tabs I guess. I thought wrong.
Re: 954 parts
Here are the guages. I said 13,xxx. I lied. There are 12,730 miles on em. And the back case has a little crack on the back. It's around the center mount if you look closely. I took the pic with the bike running so you could see the tach works too.
Re: 954 parts
I have a stock exhaust can, air filter, and motor mount bolts from an 03......all are in excellent condition, swapped for aftermarket parts shortly after I got it. Let me know via PM.
Re: 954 parts
I'm waiting on a response on the guages. Shoot me an offer on the frame. But no noballing Fairing I'll take 75 plus shipping on. If I don't get a response on the guages today, I will let ya know.
Re: 954 parts
I'm passing on them as well. You cant buy a replacement lens for it.
http://www.bikebandit.com/houseofmot...r-2002/o/m2075
Bikeparts92
11-24-2012 10:04 PM
