2000 r1 parts wheels, forks, upper tripple, brakes,carbs,harness swingarm misc
jay contact me 2 tohype4u2@aol.com or 646-479-9256 4 parts
Left over parts 2000/2001 Yamaha R1
e mail or om me whith your requests I am half way through the dismantle ,
everything plus shipping
new clutch cable 25
seat front $ 30
radiator w fan and resevoir no leaks 110
damaged radiator had a pin hole repaired with epoxy needs to be redone leaks drops w/ good fan 50
carbs stock $ 100
scotts steering damper top mount only (I may keep the damper for next bike ) $75
kickstand 35
swingarm polished $65
rear shock $50
rear calipers$60
front calipers$ 65
complete harness $100
mirrors minor rash $10
clutch perch 35$
tripple upper clamp polished needs to be repolished $75
wheels polished lip $250straight as an arrow fits 99-03
cush for sprocket $ 10
forks straight $175
rear master cylinder $30 l
hed clutch cover has 1 welded hole its ugly but doesnt leak you cant see whn plastics are on
used stay slightly tweak at the base easily reapired $65
ignition switch/ cutoff $30
signal / light switch $25
rearsets 110 right side peg is chipped I have aftyermarket replacements I will include
brake rotors front stock $100
rear rotor $25
new clutch cable 25
seat front $ 30
carbs stock $ 100
kickstand 35
rear shock $50
rear calipers$60
front calipers$ 65
clutch perch 35$
forks straight $175
rear rotor $25
