Engine Cage Freestyle Ingenuity CBR F4i
This cage has been down once. When I unmounted it, it wasn't tweaked or anything. Everything lines up fine. It will mount to your bike as good as new. I took pictures of the damage. It is mostly just paint, I didn't paint it so you can see it good. The frame sliders are darn near perfect except the plastic caps are a little warn on one side. The threaded bolts are a little stripped that attach the cage to the subframe. You'll need to buy new ones from the hardware store. The threads didn't match the stock nuts' threads that FI says you are supposed to use. It just messed them up. 2 bolts would be just a couple of bucks I'm sure. Only asking $130 shipped. It was $275 new and it will work very well. It is a very light cage but surprisingly strong.
BlackMarketBike
07-09-2024 03:25 PM
