F4I and 600RR parts Cheap,, headlight switches, rectifier, airbox, triples etc
I cleaned out and went though everything i have pretty much and found a few more parts i dont need for the f4i and RR
F4I
Leftside headlight/turn signal switches good shape $20
Airbox w/ stacks, lid, filter, ram air tubes $15
Upper triple clamp good shape $25
Ram air tubes $5
Rear rotor w/ bolts $10
Rectifier $10
Heelguards $3
Brake stay/caliper mount rear $5
set of 6 cush rubber $5
radiator cap $2
overflow bottle $2
Coolant temp sensor $3
Set of motor mounts $5
Front brake lines $5
Rear brake line $5
chain adjusters (one is missing bolt) $3
Forks slightly tweaked $free
Rear axle no nut $3
Front axle no bolt $3
Swingarm pivot bol no nut $3
Clutch pressure plate $5
600RR
Headlight switch/turnsignal $20
rectifier $10
also have aluminim lis plate bracket mounts on rear axle $20
600rr swingarm extensions $35 engraved 600rr very small hairline crack in one about 1/4" long i used as is never knew it was there easy fix.
If anyone is interested in it all take it dirt cheap No use for it
F4I
Ram air tubes $5
Rectifier $10
Heelguards $3
radiator cap $2
overflow bottle $2
Rear brake line $5
Rear axle no nut $3
600RR
rectifier $10
