929 fuel pump issue?
I just swapped sub frames... and while it was off, I washed the bike. Putting it back together I blew the main and sub fuse. After I replaced them the fuel pump doesn't stop priming. Like when you first turn the ignition on... the fuel pump usually primes and then stops... well now it keeps on pumping. The bike runs... but I don't want to burn out the pump or anything. Anyone had anything like this happen or know what it could be? Thanks.
