gas problem
"Back on the Block"
gas problem
when I'm up on one gas leeks out of my overflow how do I keep this from happining. it's alot of gas I routed my line off the back so Im not geting wet but I'm still loseing gas.
Re: gas problem
Originally Posted by BLADE919.B-MORE
I think so our maybe the over flow hose?
you know the little hole up under your gas cap, overfill your tank so it goes into that hole an see if its the same hose you say is drippin.
if its not the little vent hose for air but the big hose just like the size going to the petcock jus plug it.
its just a overflow i capped mine on my 94
Re: gas problem
i got a better fix, get a vortex gas cap (or a good stock one)
cause if gas is coming out of your tank and into the overflow, even if you cap the overflow, gas will still be coming out of your tank and then it will go all over your tank
just a thought
just a thought
Re: gas problem
just a thought
just a thought
