01 gsxr oil Leak from head
hey can somebody please help!!!!!!? my gsxr has a oiL Leak on the front of its head just under the header flange it looks like a bleeder it has a lil ball in it I have no clue what this means? I just need some help 2 get my baby back on the road so please!!!? HELP!!!!
Re: 01 gsxr oil Leak from head
directly under each header (exhaust port) there is a small hole, its a bleed hole from where the spark plug lives, so any water (or oil in your case) can drain out away from the plug.
Im guessing you have a problem further up on top of the head so the oil is running down into the plug hole and out the front of the head.
Take a look on top of ya cam cover and also inspect where your stick coil goes in as there is a rubber gasket between the head and the cam cover, round each coil/plug hole.
Hope this helps?
EDDy Red beard
PS for a parts brake down try www.alpha-sports.com and look up the suzuki parts diagrams
Hope this helps?
EDDy Red beard
trabich
11-17-2012 12:15 PM
