coolant overflow hose leak. (Stuck thermostat?)
I have a 03 600rr and after the bike idols for a few min the temp rockets and coolant sprays out of the overflow hose. I had the radiator pressure tested and the cap tested and there were no leaks, I think it could be the thermostat sticking. Any suggestions?
Re: coolant overflow hose leak. (Stuck thermostat?)
Bike is in the shop now and my guy is gonna go with a new cap today so il test it out in the next couple days and see what happens. Thank you
"Keep Your F4i's IDIOTS"
Location: deep dirty south Illinois you fucks not missouri
my f4i is kinda doing the same thing........i already swapped the cap and rubber cap on resivoir
have you made sure your coolant is properly bled? Run the bike with the radiator cap OFF tell it gets to around 200f, then put the cap on
Hm, have you tried flushing it? it could be a blockage, or something built up in the cooling system if the temp rises quickly.
If all else fails because you have
-Completely purged the system
-have the proper mix
-flushed the system
-have the cooling system cooled
-fan is running
Worst I would have to say is that it could be the water pump, but only if the temp rises, and stays high.
-flushed the system
-fan is running
coolant should come out of the radiator at 220 and go into the overflow bottle and then when the bike cools down it will get sucked back into the radiator ..
if the overflow bottle is over filled it will then leak out the over flow hose on the overflow bottle , there is a hot and cold full line on the bottle ..
lets clear this up mabe the hoses are backwards
the top is going to the radiator and the bottem is going to ground
