Help.. F4i starting problem???
Ive been puttin this 02 f4i back together and it has started up atleat 20 times. i took it out for a test ride today and when i got back it wouldn't crank. the gas take primes but when i hit the start button the headlight turns off as it should but it wont turn over. Any suggestions as to what this could be???
bank angle sensor is bypassed.
i believe that it is a short it the wiring right coming out of the right side control but want some insight before i go trying to track down a shorted out wire.
thanks for the help
justin
thanks for the help
justin
Re: Help.. F4i starting problem???
check all your fuses first, including the one in the starter relay (solenoid)
if your wiring is all ghetto rigged then that sounds like a good source of your problems lol
kntmare181
02-14-2013 01:00 AM
