Help with 600RR engine problem!!!
I have a 2005 cbr 600RR, Was running fine Ran turbo blue in it, And it will now act like its hitting rev limiter at like 7,500rpm..In neutral or with clutch in it will go all the way till redline..But under a load wont go over like 7,500rpm..Any ideas, Tank was almost empty filled it with 87 octane..Still doing the same thing figfured it was the gas..Any ideas?.. Of wat it could be?..Please pm if you have any..Thanks
Re: Help with 600RR engine problem!!!
i dont think its the clutch, it sounds like you injectors are clogged.
its definately not any thing in the motor, but its not getting enough air or fuel,
did you wash you ur bike and cover the air box on accident? it happens.
drain the throttle body of all the contaminated fuel and try it then.
it could also be clogged injectors
