Help pulling an F4i motor
Old 11-12-2007, 10:13 PM
WWW.Sickinnovations.com
Suicidl's Avatar
Re: Help pulling an F4i motor
Originally Posted by MikeM
I dont even bother loosening the crown nut. When you loosen the 12mm hex, it takes the crown nut with it.
when you put the new motor in:
tighten the hex bolt finger tight, then back it out half a turn
then tighten the crown nut finger tight
then you tighten the hex bolt, and it automatically tightens the crown nut
put some muscle into it
exactly
Suicidl is offline
Old 11-23-2007, 08:08 PM
golfmaster's Avatar
golfmaster is a decent person
unless the ones on your bike are overtightened
and then you are fucked unless you make a tool for it.
golfmaster is offline
Old 11-24-2007, 09:13 AM
JOELTAN's Avatar
JOELTAN is an unknown quantity at this point
we took a 1 1/8 socket and cut 4 prongs to fit the crown , thats prolly the easiest way we found
JOELTAN is offline
BlackMarketBike
07-09-2024 03:25 PM
b16_rex
05-02-2020 04:49 PM
SprinGZ
02-26-2013 02:01 AM
stunter559
02-20-2013 11:14 PM
Slider
11-12-2002 09:54 AM
Quick Reply: Help pulling an F4i motor
