hot start problem
hot start problem
ok guys , i need some help on this one . im having hot start problems on a f4. turns fine when its cold , or been sittin for like 20 min - 1/2 hour . but if i stall it and try to restart its acts like a dead battery . ive tried different batteries , changed the ground and starter positive wires , thought the starter was heat soaking so tried that . i cant figure this issue out . it will jump start fine , but wont crank when its hot. every sensor , and both harnesses have been changed , and it still does it .
all the problems started when i changed engines . ever since i have been fighting this problem . thanx in advance .
scott
scott
