F4i fun: fuel problem
Re: F4i fun: fuel problem
im new to ive been out at the spot since december and just got my bike right..change the plugs put the ngk in it run some good gas with the sea foam in it and i bet it will fix it, and even if it doesnt dont get dishearted becuz when you do get it 2gether i promise you wil LOVE it :YEAH:YEAH:YEAH
did that, but the more i research the more i think its the ignition. everything works alright when i jump the resistor plug for the fuel pump. i think its just a bad ignition switch. i put factory ngk's in bought30 miles ago and ran a full tank of seafoam thought it now. Does anyone know the proper resistance for the ignition swith, i could just replace the resistor....
just post up on here im sure there are cats around you somewhere, or jus do what we do scout industrial parks eventually u will find people who wont call the cops... oh and you would be surprised what asking permission from the owner of whatever spot you go to would do especially if its private property...burnouts and actin a fool will get you kicked out of a spot quick so if you get permission on private property cops cant do **** and if you act like you have a little respect for property you will keep your spot:YEAH
yeah maybe just got to get running right. did you get you beast up and running? i pulled my power commander and pulled the spark plugs the other day. i also order a new used wiring harness and ecu, i hope this works damn money pit!
