front brake prob help.......
#41
Re: front brake prob help.......
squeeze the brake lever and crack open the banjo bolt and close it... its messy but air gets traped in those to... u need to bleed each one on the calipers and on the master cylinder...
#43
awesome. gonna try it out. thanks a lot, dude.
#44
well i switched back to my stock master...i tried the bleeding of all the banjos,bleeders to no avail.......i eve switched the levers to see if that could be the prob...nope so eve after all the bleeding it got worse...when i would squeeze and the lever would not release.....AND my calipers are still freezing up.........but my stock works much better......soooooo what calipers fit a f4i....
