another hand brake problem.
ok so i got the hand brake installed it bled it. now when i use it the pressure stays and wont release. i have to use a bleeder to let the pressure off. any one have this problem and some help to correct it.
Re: another hand brake problem.
that should work but if it doesn't you may have some crap in your front master or the lever isn't releasing the rod that pushes the piston inside the master..
check the front master for damage that may be causing the lever to stick
alright, i took out some oil, and the foot brake works great, but the lever gets stuck. so i guess i'll take it apart and see what i can find. thanks guys
I had the same problem. Caliper would squeez but not release unless I released the bleeder. I figured it was the master so I took it off and bought a bremo. Should be in the mail today so I'll tell if it worked.
ther is a pressure release hole in side the master that lets the fluid go back in to the resivour if it has a peace of crap in it then when you pull the hand brake it will cause the brakes to stick...
an easy way to tell if its clogged is to blow thru the hole that the brake line bolts too and with the cap off the resivour you should be able to here air coming out of the resivour,do this test with the lever off and then with it on if it flows air with the lever off but not with the lever on then you may need to grind a little off the pin that pushes the piston inside the master....
if it doesn't flow either way then you have a clogged return and you will have to take apart the master and clean out all the holes
Depending on the adaptor you used your banjo bolt may be too long and bottoming into the scavenger port plate of the rear master. Grind down the banjo or if you dont have access to a grinder place 1 extra crush washer in the mix. Look into your master, you will see a circle where the banjo bolt was bottoming into the master. Kinda like trying to drink out of a straw when the end of the straw is square against the bottom of the cup....ya dig?
greenhornet347
03-24-2013 12:22 AM
f4i knight
02-26-2013 03:06 PM
OneWheelRegulator
12-02-2012 01:25 AM
