F4 and F4i parts compatibility?
Are all the parts compatible between a 600 F4 and F4i
i.e Master Cylinder, Rotors, Brake pads, Front/Rear rim?
Also can you put a F4i motor in a f4?
Thank!s
Thank!s
Re: F4 and F4i parts compatibility?
ALLRIGHT i just found out that the Front wheel and rotors are NOT compatible between an F4 and F4i However the Rear ROTORS are the same and are compatible.
Can anyone please input more here....
subframes can be switched...forks with the rite wheel...clipons rearsets upper with the rite upper stay....rear rim with rite spacing...etc
ummmm what else do ya need to know???
I tried putting an F4i wheel, the spacers would not work from the F4i and neither the F4.
Basicly i want to know If you can u put a Whole 929/954 FRONT END on a F4?
Any modification required?
um from what i know of you should be able to put thw whole front on...99% sure you have to switch out the neck bearings to make the switch....if its the whole front end..like forks rim clips brakes tripples??? it should work...
