Help! F4 1999 carb problems
Hi there,
I'm rebuilding a 99 F4 to a stuntbike.
Now i've heard about a problem whith stoppies and wheelies whith this bike because of the carbs??
Does anyone know more about this problem and how to solve it?
Thanks a lot!
Thanks a lot!
Re: Help! F4 1999 carb problems
Is still think its a weird solution to just close the fuel supply.
Hope to hear different solutions
Are there problems whith high wheely's to?
go try it out steve! just roll some stoppies as soon as you get the dirtbike bar, see what it does.. maybe its not too bad, maybe it is..ask scott chychul on this forum, he kills an f4!
Oh and the carbs are fine for wheelies. Even on the bar it doesn't sputter before the oil light comes on.
Oke. I recieved an e-mail whitch sayd that just turning the fuel pump off isn't enough.
Until now the only solution is to close your fuel line whith a valve.
I'm going to inform if it's possible to do this whith a swith and a electric(magnetic) valve. Hope it possible and not to expensive.
--*CBR*KING*--
04-05-2022 11:42 AM
