will an F3 fuel pump work on a 900rr?
mine just crapped out and i know the F3 has a low pressure pump on it, and may be easier to find. just didn't know if the electrical connections would work or not.
Re: will an F3 fuel pump work on a 900rr?
I'm not sure, but the best way would be to go to an online parts store and see if the honda part numbers are the same. I know that a 900rr fuel pump works on an 89 hurricane.....
they have different part numbers, but i'm not sure what might be different other than maybe how they mount. if i find one i might just have to try to rig it up.
Originally Posted by Wheeliest
autozone sells 12volt fuel pumps, 6psi ones i believe and higher.. they are cheap to.
99gixxxer750
12-16-2012 09:12 AM
