engine brake or pain in the ass???
engine brake or pain in the ***???
ok im rockin my dirt bike for a while got a lil better with rear brake, and decided it was time to step it up to teh big bike after a 20-25 mph accident on the dirtbike fliped wheelie.. anywasy back to topic, on my bike (yzf600r 02') the rear break lever is in a fuked possition and i cant cover it without being uncomfortable. im still in eth squid stage with the big bike do to this problem , im riding rev limiter **** at about teh bp, i went behind ti this moring on way back from work at about 60 and almost craped my pants befor i let off enigine brake saved my *** (thanks SPORTBIKE) lmao anyway, should i cut and weld a peice or suttin into teh lever so i can cover it to use the rb? or contuine relying on teh engine if i go behind bp? keep in m8ind im not trying to do slow **** rigth now, all i want to do is hold a steady wheelie for like half a mile or so and ill be happy...
Re: engine brake or pain in the ***???
if you go past balance point engine braking aint gonna do nothing for you buddy . Ive never heard of a custom brake lever so that its easier for you to cover it , i think your just gonna have to be unfortable and cover the rear brake, you really dont have to worry about it though unless you get it beyond balance point.
Ok, forgive me if i sound condescending but, there isn't any way to adjust it? I know that on mine i just take one of the little wrenches in my tool kit and turn the bolt that is connected to it to adjust it... But I'm not sure about your bike, worked on mine.
if you go past the bp, engine break can bring you back...adjust the rear brake pedal to where its comfortable, learn your wheelies without it, but your gonna need it to be comfortable just in case.
Will that tt-r be for sale any time soon?
lmao, the ttr should be broken soon, one more good whipe out on it... lmao.... and i had a mechanic friend of my moms look at it (600) and he sayed "new lever" or cut brake cyclender or some **** like that..i was like wtf thats gay, the lever is in perfect spot on my dirtbike, if i can rember correctly i have talked to more than a few people with same model bike that have fuked *** levers... seriously bad positioning, i ride everyday with foot under the lever a few inches!!!i punno about you but when my body andgle is tward the front and the peg to rest foot on is about the same hight as the lever makes it gay as hell, i cant bend my foot that way lmao... i dont think its physcially possible
oh so its too high, thats wierd that you can't adjust it...Stop wiping out on the tt-r, i want one real bad, getting tired of the fiddy. Is that the tt-r in your avatar, you make it look like a fiddy, you must be huge.
^he's got a point.. someone doesn't understand EB and BP... it should be able to adjust.. or just move your fvckin leg, i know a kid on a yzf who kills his... stop complainin and rock some ****!
I stunt a YZF, cover that rear brake !, & if your going to be wheelieing it alot now, then you might want to invest in a cage. I got one fabed up at the local machine shop, after replacing stator & cover=$$$$,
Originally Posted by Lb3
you dont know what you are talking about. if you have any gearing you can engine brake off the bar with no clutch or brake easy. all you have to do is wind it out.
Ive never been balance Point , but your telling me if your going 75-80 mph on one wheel and you get it high enough that you are behind balance point you can engine brake fast enough to bring it back down , it seems like youd be going fast youd just flip it.
oohh jeeze the faster u go the higher the Rpm's are and the higher the rpm's are the more engine brake u have. It's not rocket science. The slower u go the less engine brake u have. Depending on the gearing ur engine brake can pull u right back into the balance point from behind it. But dont get to trusty with doing that until u know u have control of that rear brake. Just in case
Yes, I am sure it is possible if you let off right after you go past balance point and is probably easier if you are geared up, BUT for a begginer they will probably loop the bike. ****, I have looped twice in my life going around 55-60mph....just got the bike up to fast with too much speed and never hit the rear brake so back back and over I went.........
Originally Posted by YZF
YZF 600R cage...
Well i definitely dont want a NEW dirtbike, but yours might be a little too ****ed up, im lookign for something in between, maybe bout a grand, im just gonna lurk around ebay for a while till one comes up in south florida.
If you keep with it, you will learn that you will learn the limits where engine braking can and cannot bring you back. When you figure the brake out, you can use it as a safety net to teach you where those limits are.
But yeah, you can go way past the bp and come back using only engine braking, how do you think people used to slow highway wheelies down back in the day before anyone used the brake? How far you can go back before looping all depends on your rpms.
