need help finding brake line fitting!!!
Tryin to assemble a brake line. I won an auction off ebay for 48" of an-4 brake line. Both ends have #4 female connections. I've been trying to find a banjo bolt to fit the #4 connection and can't find anything but #3. Maybe i screwed up by getting this line but it was only $18. Does anyone know where i can order a fitting from.
Here the auction. http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Re: need help finding brake line fitting!!!
this might be what your looking for:
http://www.jegs.com/cgi-bin/ncommerc...56&prmenbr=361
or
http://www.jegs.com/cgi-bin/ncommerc...54&prmenbr=361
or you could always get the #3an to the banjo fitting, and then get a #4male to a #3 female adapter
or
#4 is roughly a 1/2" ID line. most brake lines are 3/16" OD (#3 AN). #4 is more usefull for like a supply line for nitrous or brake fluid from a remote resevoir, or for a pressure line for a gauge. either way it should be fine.
yea 1/2" is pretty big... you should still be able to use it though. Hmm... you could always slap it back on ebay, and get you a 3an one. There's a local place here, that does nothing but make fluid lines. I got a 3/16" braided line 60" long w/ 2 banjo fittings on it for something like $40... I'm not sure what that line is made out of, but there's different materials that have to be used for brake fluid ( i can't remember if its brake fluid or something else, but i'm pretty sure its brake fluid).. just search around on jegs.com or summit.com and see what ya can't find.. if they don't have it listed, call there tech lines, and they should be able to hook you up with something.
