900RR parts
900RR parts
Hey,
I just picked up a 94 900RR for stunting. This is my 1st honda as I am a Suzuki guy so I dont know much about them. I have 2 questions.
The front breaks are realy bad. I think one rotor is shot bad!! Any way what year bikes can I exspect to work on this I need 1 or 2 rotors. Havent pulled off the whell yet.
2nd one is the back brakes suck bad. Is this aHonda thing or should I replace every thing from oi and lines and pads.
Im going to trash this thing but want to have it safe. So any help would be great.
Re: 900RR parts
you will need 93-95 model year for the rotors...i have a set of straight ones, make me an offer.
i also have a some other parts that i've been too lazy to sell:
extra front and rear rims for your year,
extra front brake setup including calipers, lines, reservoir, and part that bolts to bars
extra front and rear rims for a 96-97 with rotors as well.
maybe rear brake assembly
lemme know
lemme know
Re: 900RR parts
lemme know
lemme know
Re: 900RR parts
lemme know
lemme know
Re: 900RR parts
Originally Posted by bill parr
i had a 94 900rr, 93 to 94 900rr th3 spedo is driven off the front axle, so ONLY 93 and 94 rotors will fit a 93 or 94 900rr. the center of rotors is larger to accomadate larger hubs. 95 to 97 the center hub on the rim is smaller , even smaller yet on the 98 to 99. i went through this when i needed rotors. it really sucked. if you want to check it out for yourself go to a dealer and have him pull the part numbers. all 3 sets of years i have noted have different part numbers for the front rims and rotors. alot of the other parts will exchange though. any 900rr back rimm will fit. they are all the same....i have a rear rim with rotor if you need it, let me know. i just sold my spare front rotors though. and im not trying to be a dick, i just dont want this cat to go through what i did. and we had all 3 year group 900rr's in my group so anything else you need to know weather or not it will interchange, just ask, if i dont know ill try it myself for you b4 you buy any useless parts.
yeah this is what i ment to say
Re: 900RR parts
i could have swore that with rotors: 98-99 are the same, but will not fit on a 96-97 which are the same, and then i though 93-95 were the same...
i know the body styles went by those years, or so i think! lol
either way, i have 99 rotors, 97 rotors, and i guess 95 rotors...the old skool rotors (95) have a crap load of holes in the rotors themeselves....and i know none of us ever had any parts older than 95...anyways. my days of RR's are done, i'm onto krapasakis now!
hit me up if you think you want anything i got...it is just sitting in my attic collecting dust
Re: 900RR parts
thats another way you can tell, 95 thru 99 all have the 3 hole pattern if you can picture what im saying, 93 and 94 look like swiss cheese. hell have him acuratly mesure the center hole in his rotors, the 93/94 are a 1/4 inch bigger in diameter. you cant go by measuring the bolt holes center to center either cause the pattern size is the same for all the years, i went thru 2 sets off e-bay b4 i found out what i was doing wrong...it really sucked...
Re: 900RR parts
Just toss that 16" front wheel, get a f3 wheel, and then use either f3 or '95-'97 900RR rotors. It will handle better, tankslap less, and you can get better front tires. I did this on my '94 RR, and it made a huge difference as far as handling goes. You just lose the speedo.
speedjunkies
01-14-2013 05:55 PM
