doing my first 12,o advise?
So ive been riding wheelies down every road possible standing up or sitting down till my arms get tired anyway. Ive started doing dead stop wheelies but am afraid to go all the way to set it on the 12, i can dead stop wheelie sitting down or standing up. what makes it easier to set it on the 12 bar your first time?
Re: doing my first 12,o advise?
not all of us are coordinated enough to master fb before going to a hb... im sloppy as **** with my foot, since i put my hb on and learned more when to break im now better at fb (but still sloppy as ****). so some of us need to skip steps in order to be better
Do you do 1 finger clutch, 1 finger on HB?
do u want to park it or scrape it and ride out...
when i learnt to park it on the bar it was foot in bar. be able to ride idle with no throttle input, let off brake and let idle pull u back, then pull clutch in right before it hits and let it fall the last little bit on the bar. pull your right foot off the peg and use it to balance till you scrape to a stop.
to scrape i ride staggered and ride at bp then just add a little trottle input and let it go back slowly till it hits. then just let off alittle bit and use the engine brake to pull it off the bar and then stay back on the gas to keep riding the wheelie.
I learned how to put it on the bar by rockin right foot covering the brake and left foot on the floor. pop that bitch up until you hit the bar. dont try to ride the wheelie out - try to hit the bar. if you pop it up and dont hit the bar put it down and try again. once you hit the bar like that it will be easier doing it either staggered or sitdown or fib or whatever.
thanks for the info everyone. i watched colton the other night at motoprimo and was trying to figure it out. i think i'll turn the idle up use a little clutch and try to attack the fb. last time i tried this i didnt have the idle up and gave it some juice while in a wheelie and dumped it on its side, boo.....
So i landed my first 12o on fri night in the rain i dumped it once and bent my bars but thats the name of the game right.
Saturday tried it again on saturday and can set it on the 12 quite well but the bike wobbles so bad that i have to set it back down right away or it tips over.
how do i get the wobble at slow speeds to go away? Im +10 on a 03rr and hittting the 12 in first gear.
what's ur tire pressure at? run 25 pds? ....could be the bar you got....BUT CONGRATS!!!! you got it right!:YEAH the more ya practice the more natural it'll feel....try scraping and tappin the brake and riding the scrape out back to the wheelie...
f4rider
05-06-2004 01:38 PM
