help me out
help me out
well i got the sickinnovations sub cage with solid pegs right now i also got the foldible peg brackets too. then i order some esd-mfg pegs for an f4i and the SI bracket wont work the pin dosent line up i can put the pin in but the peg wont lock out in the flat position ITS WAY OFF anyone have this prob.
Re: help me out
your problem is you should have given the pegs to me...
also i read in a myspace bulliton garbage wheelies clog peg brackets! there for...
HAHAHHAHHahahaa
wers OMR with his subcage plug?!
HAHAHHAHHahahaa
Re: help me out
huh!..lol
scott as long as the pegs have enough meat to them you can probably just grind the back side of the peg but i can't see exactly where the problem is so i am kind of guessing...can you post pics ,maybe i could help you out
esd pegs fit in an OMR SUBCAGE......i couldn't help my self...lol
Re: help me out
just be carefull not to grind to much or your prgs will point down and you don't want that , you can always take the peg off and grind a little more off but if you take off to much you will have to add material to the cage and that would require a welder
Re: help me out
huh!..lol
