how to air box mod f4i
#122
Re: how to air box mod f4i
I definitely noticed an improvement
Went from rocking idles on my f4i at 3k-3.5k only getting down to 8-10mph indictated and my bike would stall out
Now im rocking 2-2.2k idle, and can get down to 5-6mph indicated on stock gearing..
within ONE wheelie of doing the clean air mod I was rocking 5-6mph instead of 8-10..
I never went above like 2200rpm to begin with.. Maybe thats why
#125
ok i moved my idle cable to the throttle bodies obviously so it would adjust better, now if i do this mod will that effect anything? when i disconnected my idle cable from stock it was pretty much set at about 1000rpm's.
#126
you need to have both cables and adjust the stock one up and down till you find the spot where the bike has the strongest idle ...
go back and read this thread and you will see what im talking about
#129
lets go with quantum physics , here a good analogy .....
lets start with a room ,in the room is a cat , the only way to look in the room is to open the door but the door is locked ....is the cat dead or alive ?
the answer is the cat is both till you open the door and see it
quantum physics is fucked huh....lol
#130
#132
oh by the way its mandys' birthday today
#136
#139
