where am i going wrong...
i cant stoppie... i tried just getting the feel of endos and applying the same amount of pressure to start the stoppie, varying pressure and ****, but i just cant roll it... what am i doing wrong... any help... i can pull up decent endos, but i cant get the dam things to roll for more than a couple feet...
Re: where am i going wrong...
as far as speed, i dont really pay attention... i pull hard through first shift to second, and the let off shortly after shiffting to second, pull in the clutch, bounce the pegs a little lean forward, grab the break like im gonna endo let the rear come up till i feel comfortable, and then LIGHTLY let off the brake so i will roll and as soon as i even let off so much a hair lash the FU(KEN rear drops to the ground...
not all the way through 1st just on it hard till i feel i am going fast enough... prolly around 30-40 range... just as hard as you would coming off a stop light if you got on it... make sense... and is a 96 900RR
well youve got 2 probs i can see, your letting to much of the brake so your coming down, work on letting of the brake a little once up, without letting it out completely, the other prob is your not up high enough, put those to together with practice and you should start rolling them farther.
bikemike
05-19-2010 06:26 AM
