learn 12s the easist way???
#41
also.... get a video camera and have someone video tape you. that way you can see how much farther you need to go other then guessing. for the most part once you think you cant go back anymore you still have another few inches.
#42
this was the first day i went out and practiced since my crash,and my wheelies were garbage,got to get rid of my fear :twelve wasnt even coming close to scrapin,or even ridin em out,got to go out in the daylight,maybe that will help
#47
Re: learn 12s the easist way???
Originally posted by hayez
ive been trying to learn 12s but i just cant seem to get it all the way,im afraid im gonna hit to hard and either loop back words or go back a little to far and crunch my tail and lose control,whats the best way to get em right?should i put a 12 bar on to help?or should i just keep doing what im doing?
#48
learning the 12
like Ant said learne the slow wheelie before you even try to tear up a tail the bar will make you wreck if you do not know what you are doing check out TEAM-XTREEM VIDIO THIS IS HOW WE DO IT 12OCLOCKS IT LETS YOU SEE IT OVER AND OVER SO YOU CAN UNDER STAND . P.S.YO MIST WHATS GOING ON IN THE NORTH SIDE
#49
Re: learning the 12
#50
Originally posted by JackassRR
Hayez..dont let the fear set in..u have to do it again and u will be fine...This I know. Ya... try in the light..dont know why but it helps when learning. I know ya got it bro!
#51
slow wheelies
If you can ride out a balanced first gear stand up,you can learn to ride your rear brake.If you can ride right at your balance point.Gearing down does help,but when I learned,I had stock gearing(that's why I crashed so bad{you gotta blame it on something}).When I geared it down and ran 15psi in the REAR TIRE ONLY it made a huge difference.Now I can get my bike(CBR900)creeping at like 8-10mph.
#52
Guest
Posts: n/a
screw lowering the psi to 15!!!!
how often are you doing 12's?---I opt for all around aggresive riding......you know,crackin it up to speed.knee down in the corners.and loft a huge endo at whatever stoplight is next.if you lower your psi to that.and try and ride.its gonna suck.try and learn everything with stock gearing and pressure.THEN bust out the craftsman tool set and change sprockets and all that.
#53
i think you guys got the wrong idea,my wheelies are down right,and there pretty slow,i was just scared to scrape my first time,i know what i did wrong now,im tryin to work on my brake control to get it better
#54
i only do wheelies etc...i dont ride no more till i get another bike,i just fill up with air if i go anywhere,thats maybe 2 times a week
#55
get a cage if your worried
I just bought a cage and bar from Freestyle ingenuity. That helps in keeping your bike from getting trashed. When learning 12's you know your gonna wreck now and again. Just get a cage to save a TON of money when you ball your bike up. And..practice, practice, practice. Be safe.
#56
Re: get a cage if your worried
#58
Originally posted by blue95accord
Good luck, and be safe. And make sure you get some pics of you doing it! South Florida stunters coming along :devil
