f3 endo-engine problem please help
So i'm out doing endos for the first time in forever on my bike cause i got my brakes actually working for once and i'm practicing them for about 2 hours and then right in the middle of one my engine dies. i tried to pop start it and it didn't work, i tried to choke it, and that didn't work. i took out my plugs and checked them and they didn't look dirty at all but i cleaned them anyways and its still not working. anyone know what would cause the engine to die and not want to start again after doing some endos? any input would help (except the ones telling me my bike is **** cause i know that)
Re: f3 endo-engine problem please help
-check 4 spark (pull a wire, put an old plug in it and hold it against the block to ground it).
-do u still have gas and that **** is turned on? (lol, dumb question, but i've seen it happen)
Other than that, I'd mainly check for loose electrical connections with the ignition module stuff. Thats all I could think of that would cause it to just quit.
i would check the sensors that disable the bike from being started, ie. the kickstand sensor, gear sensor, did you hit the kill switch? i've done it before, and not realized it for a while : i dunno what else to tell ya
yea i say you on ran it out of gas from being on the nose, and not getting fuel, check gas, kill switch, kick stand switch. If all good just choke it and keep tryin to turn it over, may have to push start it, because the carbs may been flooded. It probly something little. I got a F3, they are a beast, but still really good bikes just a little heavy since steel is the main metal in the bike.
I know that it isn't the kickstand sensor, kill-switch, or knock over sensor because Tenny doesnt have any of those hooked up. It didn't run out of gas either. So maybe that helps you guys out.
Originally Posted by MikeM
Check the fuel pump too. If it dies, it'll block the flow.
tenny, if your not gettin headlights or any power, its probably the main fuse for all power, its behind the battery box in a rubber boot(careful if u check it though, the one that is visible is a spare, u actually have to pull the plug out of the boot to check it, i checked it one time and it ended up bein the spare i checked and i was kickin myself in the *** cuz it still wouldnt start, so heads up) , its a 30.... i blew mine doin somethin stupid one time... check that out... later man.. P.S. Sorry bout the delay on buyin the cage off of you, i had mad bills the past 2 weeks, ill get it off u ASAP.. :YEAH
Check up under your guages. My buddy had on of those plugs come loose. It didn't come all the way out so it took us a while to find it, so check them good. Let us all know when you fix the problem.....
Originally Posted by Stunt Jester 1
yea that dam thing a lot of fun to change, just make sure to unplug the batter before dick with it, because if you dont you can blow the relay if you hit the two wires together, and i bet that thing is not cheap.
relay (starter solnoid) costed me 9 dollars off ebay :P i didn't think that f3's had a fuel pump so i'll check that **** because it is totally acting like it isn't getting fuel or maybe my plugs are sparking. i'm going to start working on it right now.
that was my guess that it got flooded but it still wont work and its been 24 hours. i tried taking out all my plugs and cleaning them and that didn't work so i'm looking to see if my coils decided to **** up or something.
