how to keep motor temps down while practicing?
Old 12-22-2003, 10:46 AM
Outkast Rafe's Avatar
man my bike is always overheating whenever i am practicing or doing burnouts i was thinking about buying that aluminum fan but does that help??
any suggestions??
also its a 01 750
Outkast Rafe is offline
Old 12-22-2003, 10:48 AM
JAVIER's Avatar
JAVIER is an unknown quantity at this point
HOW ABOUT A ON AND OFF SWITCH FOR THE FAN
JAVIER is offline
Old 12-22-2003, 10:52 AM
well thats the thing its always on and sometimes i will let it cool down and park it but dont turn the key off just so that the motor can be off but the fan keeps running its just that it hot here in new orleans i now you florida guys can relate
Old 12-22-2003, 10:55 AM
BTB Matt's Avatar
BTB Matt is an unknown quantity at this point
Do some stoppies. Comin in at 80 every once in a while will cool your **** down.
BTB Matt is offline
JAVIER's Avatar
I JUST GOT A SWITCH AND WEN IM OUT PRACTICING I ALWAYS KEEP IT ON
JAVIER is offline
Old 12-22-2003, 11:09 AM
Gas'er!!
TEACH C6's Avatar
what javier said...i run a 954 rad. on my RR so it is always on and i notice that my bike runs about 15-20 degrees cooler just because i never shut it off...
put the fan on a switch and then just leave it on whenever you are going to be doing anything besides normal riding...
Teach
TEACH C6 is offline
Old 12-22-2003, 11:33 AM
cool
anything else i should prep my bike for
i notice in another thread i guy said something about a pvc or pcv mod
im just wondering what else you do to the bike to keep everything good while stunting
i dont ride the bike on the street anymore
thanks for any help
Old 12-22-2003, 12:38 PM
Lb3
Lb3's Avatar
I have the same problems with my 750. I ended up installing another fan so I have 2. The second one is wired up with a switch so I just flip it on when I practice the burnies.
Lb3 is offline
Old 12-22-2003, 12:44 PM
Banzaibany's Avatar
Banzaibany is an unknown quantity at this point
Maybe all you need is to clean your Cooler. Otherwise a Stronger Fan (or a second one should help you out).
Banzaibany is offline
Old 12-22-2003, 12:45 PM
Division1 Ryan's Avatar
I got a 00 750 I hot wired my radiator fan to a switch so I can turn it all the time especially small parkn lot shows. But.... remember to turn it on before you start. When I first installed the switch I would forget to turn it on then I would look at the temp and it would be @ 270 or somethin after 10 minutes of ridin.
Division1 Ryan is offline
Old 12-22-2003, 12:51 PM
HOLDINGITBIG's Avatar
HAHHAHAHAHA ... that's beat ...
anyways, I got a few 750s and the ones that i use JUSt for slow ****, I just hooked the fan power to constant power, so the joint is ALWAYS on. That's 2 fan thing is a pretty good idea too. Clean out your system with fresh coolant and then re-wire the joint so it is on sooner, or always
HOLDINGITBIG is offline
Old 12-22-2003, 12:52 PM
GOODBYE STUNTLIFE
Droptop's Avatar
Droptop can only hope to improve
Here's the Fix.... Trust me this will Fix the whole problem.
1. Make sure your radiator is totally clean and functional.
2. Go to the store and buy water wetter or blue ice water treatment.
3. Drain the engine and radiator completly of any anti-freeze and refill with just water and the water wetter or blue ice.
4. Wire up the fan so it comes on immeditly as soon as you start the bike.
5. Doing some endos will help also... But the above should help you out completely.....
Droptop is offline
Old 12-22-2003, 01:05 PM
A Few Loose Screws - DVD
CRAZY DAN's Avatar
CRAZY DAN is a decent person
yup yup
CRAZY DAN is offline
Old 12-22-2003, 01:13 PM
JAVIER's Avatar
NOW I KNOW WHAT YOUR PROBLEM YOU RIDE A GSXR 750 YOU NEED A HONDA
JAVIER is offline
Old 12-22-2003, 01:49 PM
DSOG Thomas's Avatar
take out the thermostat
DSOG Thomas is offline
Old 12-22-2003, 01:58 PM
TheShirtCave.com
DerekLee's Avatar
DerekLee is an unknown quantity at this point
I'm ruinning, "Engine Ice" coolant, with a little "watter wetter" additive....
Wire the fan to stay on and you should be good. Don't forget the 20-50 V-Twin, Mobil 1 oil overfilled by a quart.... It'll save your engine.
DerekLee is offline
Old 12-22-2003, 02:03 PM
AGGRESSION!
E-DUB OM's Avatar
E-DUB OM is a decent person
WATER WETTER works like a champ.......just add it in
E-DUB OM is offline
Old 12-22-2003, 02:12 PM
RICHARDTL1000's Avatar
RICHARDTL1000 is an unknown quantity at this point
HAY DEREKLEE WOULD YOU ADVISE THAT 20-50 FOR ALL STUNT BIKES?
RICHARDTL1000 is offline
Old 12-22-2003, 02:18 PM
GOODBYE STUNTLIFE
Droptop's Avatar
Come on know!!!! Lets not bad mouth suzuki.... I got a honda at my house right now that over heats just as much as a suzuki that I own!!!!!!!
Droptop is offline
Old 12-22-2003, 02:19 PM
GOODBYE STUNTLIFE
Droptop's Avatar
The only reason I say to drain the anti-freeze out is because I use to drag race on a professional circuit and by taking the anti freeze out it keeps it cooler about 10 degrees.... just my experience.. but if you live some where were it is cold dont take the anti-freeze out because your block will crack!!!!
Droptop is offline
Quick Reply: how to keep motor temps down while practicing?
