how to keep motor temps down while practicing?
Old 12-22-2003, 02:30 PM
Outkast Rafe's Avatar
so wait where can i find wetter water witter
and also did i hear you correctly you use a 20 50 weight oil and you over fill it ???
that means you put 5 quarts in your bike???
Outkast Rafe is offline
Old 12-22-2003, 02:42 PM
I Have Too Much Free Time
Jay Carnes's Avatar
Yeah, wire the fan w/ an ignition (switched) wire. so when you fire that hog up it comes on constantly.
Jay Carnes is offline
Old 12-22-2003, 02:56 PM
GOODBYE STUNTLIFE
Droptop's Avatar
Droptop can only hope to improve
Watter Wetter Comes in a clear bottle and is pink in color... you should be able to get it at a Bike shop or a high performance shop!!!
Droptop is offline
Old 12-22-2003, 02:59 PM
AGGRESSION!
E-DUB OM's Avatar
E-DUB OM is a decent person
hit up PEP-BOYS......they carry it
E-DUB OM is offline
Old 12-22-2003, 03:45 PM
TheShirtCave.com
DerekLee's Avatar
DerekLee is an unknown quantity at this point
Yeah pep boys should have Water wetter. Any decent speed shop or bike shop should have "Engine Ice" too, it comes in a half gallon jug and is a blue liquid. Has NO anti-freeze proerties in it though...
As for the oil, I don't really know. 10-40 wt. oil will run at 10 wt. when hot and 40 when cold. So they way I ride, my ****'s ALWAYS hot, so with 20-50, I know my oil's still got a good 20 wt. vicosity... which would be the same as 10-40 under normal riding conditions.
Then again, what the **** do I know? I may be wrong, somebody please tell me if I am. I destroy bikes for fun... LOL
But Mobil 1 Motorcycle oil is the best **** out there from what I know....
DerekLee is offline
Old 12-22-2003, 04:09 PM
Zuki750's Avatar
You are incorrect. The first number is the cold number. A 10w40 pours like a 10 wt. when cold and acts like a 40 wt. when warmed up. Also the warm wt. should be at normal operating temperature not just when super hot.
Zuki750 is offline
Old 12-22-2003, 04:34 PM
so are you still putting 1 extra quart into the bike???
Old 12-22-2003, 04:39 PM
TheShirtCave.com
DerekLee's Avatar
Damn, you're right. He're some info on oil though...
QUOTED from another site: "Viscosity Index is an empirical number indicating the rate of change in viscosity of an oil within a given temperature range. Higher numbers indicate a low change, lower numbers indicate a relatively large change. The higher the number the better. This is one major property of an oil that keeps your bearings happy. These numbers can only be compared within a viscosity range. It is not an indication of how well the oil resists thermal breakdown."
"Very few manufactures recommend 10W-40 any more, and some threaten to void warranties if it is used. 20W-50 is the same 30 point spread, but because it starts with a heavier base it requires less viscosity index improvers (polymers) to do the job. AMSOIL can formulate their 10W-30 and 15W-40 with no viscosity index improvers but uses some in the 10W-40 and 5W-30. Mobil 1 uses no viscosity improvers in their 5W-30, and I assume the new 10W-30. "
DerekLee is offline
Old 12-22-2003, 04:43 PM
Old 12-22-2003, 05:07 PM
TheShirtCave.com
DerekLee's Avatar
I do. I recently Burnt a bearing on my Gsxr1000, WAY too quick. I'm not taking anymore chances... 8 dollars for an extra quart or a grand for a new motor.
DerekLee is offline
Old 12-22-2003, 05:11 PM
but shouldnt the extra oil cause problems??
Old 12-22-2003, 07:32 PM
It Ain't Easy Bein Cheesy
Dano's Avatar
not really, the crank may have excess windage which could cost a few horses but your motor will always be lubricated. The only problems i can imagine might be oil leaks or something similiar but i've been runnin an exta qt since i bought the bike new and everything's still cool
Dano is offline
Old 12-22-2003, 11:41 PM
  #33
WRooster250F's Avatar
WRooster250F is an unknown quantity at this point
I remember hearing some sh*t about the 929 being great for verical stuff because of location of the oil pump it keeps oil moving in the motor. Any1 want to confirm that?
WRooster250F is offline
Old 12-23-2003, 12:34 AM
  #34
yea i heard that too that the oil pick up was in the back of the motor
SlitZ
05-06-2013 06:24 PM
knowlzy0791
05-01-2013 01:31 PM
chef636
02-15-2013 01:23 AM
clepire
02-03-2013 03:02 PM
Quick Reply: how to keep motor temps down while practicing?
