carb issues, little help?
Old 08-29-2009 | 11:35 PM
r6roadrash's Avatar
r6roadrash is a decent person
hey guys i got an 02 r6 with jetted carbs, i just recently put in even smaller main jets to see it that could help and it did, can power up on 1 in 2nd gear now but my idle is messed up.
when i blip the throttle, the rpms hang up at around 2-3k for 3-8 seconds
then it idles back down to around 1 grand. ived tried to richen it a few times and now ive backed the mix screws out to 3 turns, is this to much or can i keep going? it seems to be alittle better now but still hangs up a bit.
ANY Advice?
thanks
Old 08-29-2009 | 11:36 PM
big ben's Avatar
CA STUNTER
big ben is a decent person
Re: carb issues, little help?
ANY Advice?
thanks
put stockers back in and clean the carbs......then try different ways and see what works.....
Old 08-29-2009 | 11:40 PM
r6roadrash's Avatar
it has nothing to to with the jets them self its my idle mixture screws, can someone with some experiance in this now give me some advice this guy doenst even know what im talking about
Old 08-29-2009 | 11:41 PM
SUPERDAVE's Avatar
HOOD CHAIN GANG
SUPERDAVE will become famous soon enough
I would put the stock ones back in and mess with the air fuel screw also make sure the carbs are in sync
Old 08-29-2009 | 11:50 PM
r6roadrash's Avatar
you guys arnt helping me here, you want me to put the stock jets back in with dif. needles. ive heard that doesnt work. the stock jets are 148 and 152 i think and right now im running 138 and 140 and you want me to put 152s back in? wont i be running supper ******* lean then? id have to turn my mixture screws all the way out or just take them out compleately so i think you guys dont understand what im asking,
sorry not to be all bitchy but ive ripped my tank and air box and carbs off like 9 times in the past 2 days and im pooped of it so i came on here to see if anyone has had this problem before i read something about it on r6forum but im not about to pay to ask a few Qs
but thanks anyway, i think im just gonna rip it apart a few more times and richen it up a little more each time and that should get it eventually. i think
Old 08-30-2009 | 06:24 PM
jonnybravo's Avatar
jonnybravo is a decent person
you have to balance the carbs.. once they are in sync the idle problem will be sorted, also have the carbs been sonic cleaned. ? whenever a bike comes to my shop with this problem thats all i ever do , take the carbs off strip em out put the jets into a sonic cleaner, refit and balance/sync them up. always works for me ( as a bike mechanic).. to be honest the smallest piece of crap in a jet will make it do this so i would start there..
hope this helps.
jonnybravo
04-05-2017 11:29 AM
Zaradomerix
06-17-2014 10:11 AM
Spawnofares
07-24-2013 02:11 PM
jmoney2001
06-16-2013 04:38 AM
