Need help/advice with Seat Standers!
Tried my first seat stander today, didnt work out to well. cant get it to BP without feeling like im losing control. Feels very unstable. Comes up sideways and stuff. Anyone know how to do them or know of a video clip showing how? and yes i do have a rear handbrake
Re: Need help/advice with Seat Standers!
I am a noob as well but i can direct you to some good advise as getting bike up smooth, i like to run my tire pressure @ 20 psi that way more tire contacts road and balance from side to side is more stable on take off...
Originally Posted by 408FAB
You should have no problem at all clutching up your 750. It's all a matter of timing.
For street wheelies, I pull in the clutch with one finger (to limit how far the lever goes back as to not completely disengage the clutch) and slam the throttle open to about 2/3 then let the clutch lever back out and close the throttle to about < 1/4 all in one smooth motion. As the front wheel lifts, I roll slightly on the gas to throttle the wheelie up.
When learning, clutch the wheelie up so that the front end has enough momentum to get you off the gound then use the throttle to bring the bike up to BP. Eventually you will get comfortable with clutching the bike straight to BP. Then you are ready for the lots!
now it will feel weird for a while when standing in various positions but this is the smoothest way I have found to be able to multi task with movement when starting a wheelie if it was from rear pegs on tail seat or front pegs it seems to help alot, side to side balance is important as well to much weight one side your bike will lean and begin to go in directions other then straight
oh yeah most important part, Be safe wear your gear, take your time 1 rev at a time....
I used to be a hurry freak till i all most destroyed my bike, and another thing i used to think well i dont want my bike broken, well if thats your only bike and u spent a good deal of money for it, respect the bike and choose, cause you will drop it and i mean will drop it.... some type of crash cage is highly recomended
I got staggards down i can ride um out a BP for bout a mile. Just wanted to up the game a lil and start something new. ill try lowering the psi in the rear and maybe that will help.
MsTandemTryOut
Missouri
05-26-2013 03:32 AM
zeus_r6
12-09-2012 09:46 AM
