how much engine oil for stunting? zx6-rr 04
how much oil are you guys use when you are going to use the bike just for stunting?
to the max mark? and a little bit more? is for a kawasaki zx6-rr 04mod
Re: how much engine oil for stunting? zx6-rr 04
i run the recomended amount in mine, if you dont have the clean air mod i wouldnt run any extra, but if you do have it done-half a quart extra is good
And lots of people think these are weak motors (as in they blow up easily)... NOT TRUE, If you can keep the RPM's in a wheelie under 9K or so they last forever... That is for you street killers... in the lot just lay off the rev-coasters and you're fine. Manual cam chain tensioner is a plus, or you can put a spring from a GSXR cam chain tensioner in the kawi tensioner and it keeps it a little tighter...
alot of people blow them up from hydrolocking them thats why i recomend the clean air mod on any 636 , once thats done i don't think the high revs hurt it
Low revs = happy bike and no motor problems...
And most people know how much I used to rock the streets, '05, '06, '07 and not one blown 636 motor..........
I used to run to the top of the sight glass (bike LEVEL!) without clean air mod, and never had a prob. BUT, I would suggest clean air, because right after I sold it the guy changed the oil, put a little more than the top, and locked the motor.......
