how much engine oil for stunting? zx6-rr 04
Re: how much engine oil for stunting? zx6-rr 04
exactly why everyone is telling you to run the kleen air mod.. your learning so your gonna be straight up abusing your bike.. so every little bit helps.
+1
And lots of people think these are weak motors (as in they blow up easily)... NOT TRUE, If you can keep the RPM's in a wheelie under 9K or so they last forever... That is for you street killers... in the lot just lay off the rev-coasters and you're fine. Manual cam chain tensioner is a plus, or you can put a spring from a GSXR cam chain tensioner in the kawi tensioner and it keeps it a little tighter...
but you dont have to fix the cam tensioner right? as long as the ticking doesnt bug ya, or am i wrong?
my xr200 ran an entire summer without oil. Then the piston welded itself to the jug, then I bought a wiseco piston and bored the jug over. ran great after that. try 3 parts oil, 1 part sand. the sand will clean the grime out of your engine, oh yeah, and did you also know you can fertilize your lawn with used motoroil, saw it on fightclub
jk, except the xr200, thats true.
