F4i fuel pump help
Old 04-08-2008 | 10:32 PM
Gixxinthemix's Avatar
Serious Squid Style
Gixxinthemix is a decent person
F4i fuel pump help
my buddy had to switch out his ignition and now his fuel pump WILL not turn on, now when we directly hooked it up it worked fine whats whats wrong i dont know hondas very well......
Old 04-08-2008 | 11:12 PM
jixxerjoe88's Avatar
jixxerjoe88 is a decent person
Re: F4i fuel pump help
its a honda, what do u expect
Old 04-08-2008 | 11:16 PM
50Outlaw's Avatar
da fiddy bitches!!!
do honda's have the resistor in the ignition or is that just suzukis???
either way, re check your wiring...
Old 04-09-2008 | 08:48 AM
Fiks's Avatar
Stunt.ca
Fiks is an unknown quantity at this point
yes you have a resistor it's probably burnt try another ignition. it happened to me also. couldn't find the problem for a while until I noticed that the pink wire on my harness was showing so it did a short cut and burnt the resistor in the ignition. I had a 929 ignition laying around and it did the job.
don't know if you can open it and fix it
Old 04-09-2008 | 09:22 AM
squidburt's Avatar
From: www.justmotorcycles.net. moorespeedracing.com. www.theriskclub.com
squidburt is an unknown quantity at this point
sounds like the feul cut off relay. i have just replaced mine yesterday bike was ******* me off.
evry thing turned on but the pump didnt prime. its under the rear seat two black boxes one of them is the feul cut off relay or somthing but that was what was wrong with mine $25 for a brand new one from honda.
HONDA POWER
Old 04-09-2008 | 09:26 AM
itr456's Avatar
itr456 is an unknown quantity at this point
Yes there is a pink wire coming out of the ignition. This wire sends a signal to the ecu to turn on the fuel pump....its only going to work if it sends out 7-9 volts. Check the voltage on the pink wire, when mine messed up it was at like 11v. you can try and wire in a resistor and if that doesnt work get a new ignition and just swap the part where the key goes in...
b16_rex
05-02-2020 04:49 PM
Napkin Legend
03-09-2013 12:03 AM
SprinGZ
02-26-2013 02:01 AM
99gixxxer750
12-16-2012 09:12 AM
Jeffknight27
12-03-2012 10:55 PM
Quick Reply: F4i fuel pump help
