05 636 engine problems LISTEN
Re: 05 636 engine problems LISTEN
sounds bad. drop the oil and check for shavings. if the oil is metallic it's toast. if not, then check that the cam chain is tight. sometimes adjuster gives and it makes sick noise too.
but the sound is more like rod big end.
usually there is always some damage to the crank too, so it may run for some time with new bearings, but it's not new.
o man , i babied that bike for awhile and now it looks fugly lol anyhoo you should always check the kleen mod to make sure the crank hose is tight on the clamps.
