Battery Problems.....
Old 05-22-2007 | 02:26 PM
MannyFresh954's Avatar
MannyFresh954 can only hope to improve
i bought a new battery put it in and it wont stay charged for over a day....heres the thing i was wondering....i changed my clutch lever to the EZ-PULL and took the stock one off and just zipped tied the two wires that goto the stock clutch that shuts your bike off if you dont have the clutch in when putting it into gear.....i was wondering since ive done that, is that drawwing power from the battery.....? thats the only thing i can think of.....
Old 05-22-2007 | 02:51 PM
Compton82's Avatar
Re: Battery Problems.....
Thats the same way I did my clutch switch and didnt have any problems, so Im guessing thats not the problem.
Old 05-22-2007 | 02:56 PM
Wheeliest's Avatar
Scrapes Elbow
check your stator connection & 12 volt regulator rectifier connection.
Old 05-22-2007 | 02:57 PM
JoeR1's Avatar
JoeR1 is an unknown quantity at this point
What about your stator? Have you tested the voltage that it is putting out when the bike is running, pick up a repair manual, well worth it
dizzie56's Avatar
dizzie56 is an unknown quantity at this point
+1, thats most likely the problem ur havin
Old 05-22-2007 | 02:58 PM
JoeR1's Avatar
damn I was writing it when you posted..
Old 05-22-2007 | 03:33 PM
thewibb's Avatar
thewibb is an unknown quantity at this point
I have a pdf of the 954 service manual here somewhere. I'd start at the stator and rectifier and check the voltage while the bike is running. There are some resistance checks you can do on the others.
Old 05-22-2007 | 04:11 PM
JRRider13's Avatar
JRRider13 is an unknown quantity at this point
I have the FSM here (Worcester) if you need to borrow it.
Boobell22
08-11-2015 05:30 PM
Duke_Montes
07-24-2015 12:12 AM
swmnstunter
08-18-2013 03:31 AM
hondacrf150f1
12-01-2012 12:34 PM
eamonhoffman
10-14-2012 08:51 PM
