what other Honda parts will fit an f2
Re: what other Honda parts will fit an f2
Any front end as long as you have the whole thing.
Iv seen a independent swing arm from a VFR 750 on a F2. Its on cycletrader right now as far as I know. Chech on ebay for the swing arm and parts to make it happen if you like that idea. There was a bunch of VFR parts on there.
Iv seen a independent swingarm from a VFR 750 on a F2. The bike is on cycletrader right now as far as I know. Check on ebay for the swing arm and parts to make it happen if you like that idea. There was a bunch of VFR parts on there yesterday.
are you saying I can put the 900 rim on my stock swingarm? And what else will fit I don't want any f2 parts on there unless nessessary.And how easy is it to put atleast an f3 upper on there?
You can swap everything from an F3 to an F2 the frame is almost identical. The only difference is the swingarm bolt is a larger diameter and you have to drill out the F2 frame.
The upper can be swapped, but you'll nead the headlight, lowers, and access covers from the F3. I can't remember, you might need the F3 fairing stay, but I don't think you do. Someone used to make a kit that swapped Ducati 748/916/996/998 Headlights onto the F3 and that improved the bike SO much. The headlight kills the look of the F3.
You can swap F4i gauges onto an F3, I found a tutorial on the web a long time ago, it was really trick.
I've swapped an F4i front end onto an F3. A machinist friend made some spacers so I could use the F4i rear wheel too. The swingarm was close, but I didn't ever put it on, got rid of the F3 about that time. You can also swap in a 900RR motor. About the time I was getting rid of my F3 I was looking into trying to swap in a 954 motor using carbs instead of efi, but I never went that far.
yeah, I got an f4i tailsection on it now , by the way does anybody got a rear seat cowl for that for sale? Also was wondering if I could put a f4 tank on it. If I Needed all the plastics to do the upper swap I would definitly go with the f4i.I also got the rear footpegs.Anybody got some f4i plastics and headlight for sale? And I definitly need a wider rim and the easiest way to do that.
