Parts to a handbrake....
Old 01-18-2007 | 04:15 PM
Brand New's Avatar
Brand New is an unknown quantity at this point
Just to clarify, and to ease my mind becuase I'm the type of person who likes to know for a fact what I think I know...what are the exsact parts needed for a handbrake?
Old 01-18-2007 | 04:18 PM
moorport's Avatar
moorport is a decent person
Re: Parts to a handbrake....
All the parts you need are in the pic right below.
http://www.esd-mfg.com/50stunt/stunt_rear_brake_kit.htm
Old 01-18-2007 | 04:30 PM
Brand New's Avatar
I already have one on my fiddy thanx anyway though, I'm leaning more towards something a little larger.....
Old 01-18-2007 | 04:33 PM
crtchrktrcr's Avatar
B.T.M.
a master cylinder, that can be flipped over...
a steel braided line
and either a. gp tech fitting that goes into the stock rear master, or b. a dual caliper setup.
that is all
Old 01-18-2007 | 04:37 PM
Brand New's Avatar
ok i got that part, now does it matter wether its a front or rear master?
Old 01-18-2007 | 04:50 PM
B.T.M.
huh??? how would you put a rear master on the clip on? or use it?
Old 01-18-2007 | 04:55 PM
Wheeliest's Avatar
Scrapes Elbow
hahah wow
Old 01-18-2007 | 05:07 PM
CHADf's Avatar
+1
maybe weld i on there or j/b weld it and zip tie it like i did!
Old 01-18-2007 | 05:09 PM
cbr_jon's Avatar
cbr_jon is a decent person
that would be a great conCOCKsion
Old 01-18-2007 | 05:17 PM
N/A's Avatar
N/A
I think what the newb is trying to say is can he use either a front or rear CALIPER?!?!
If that is what you are asking then you can only use another rear caliper if you go with a dual caliper setup. Otherwise, contact Full Throttle Inc and get yourself the goodies for a hand brake setup.
Old 01-18-2007 | 05:19 PM
eazenutz33's Avatar
dont forget the brake rectifieer if your doing a single caliper set-up, or a split-valve for the dual caliper set-up.
Old 01-18-2007 | 05:21 PM
GAMstunts's Avatar
GAMstunts is an unknown quantity at this point
get a full throttle Lower Master, and a brembo, or radial master off a 05 gsxr upper master. Some steel braided line from the top master to the bottom, then from the lower master to the caliper, couple of banjo bolts and your all set, except for the hour of bleeding, and cleanin y0ur **** off after your done spillin brake fluid all over it.
Old 01-18-2007 | 05:24 PM
Brand New's Avatar
Look man, I work on cars, not bikes, only bikes i've ever worked on are dirt bikes...simply asking a question.....
Old 01-18-2007 | 05:39 PM
Nine54f4i's Avatar
Nine54f4i is a decent person
1. Front Master Cylinder 05/06 R1/R6, CBR1000rr, Brembo 16x18 etc...
2. Brake line Steel braided 48" - 52" and Banjo Fitting for the front and Rear master
3. Some type of Handbrake Adapter Such as http://www.haibikeshop.com/store/ind...&products_id=4
4. Or Skip #2 and #3 and get http://www.haibikeshop.com/store/ind...&products_id=3
Old 01-18-2007 | 05:42 PM
kj's Avatar
kj
Correction on #2:
Save yourself some headaches and get a 54" line... better to have a little slack than none at all.
Old 01-18-2007 | 05:49 PM
Nine54f4i's Avatar
Yeah wasnt sure on the 600rr 48 fits nice on an f4i.
Old 01-18-2007 | 05:55 PM
B.T.M.
and i responded? that was one of my less ******* responses too.. i just can't win now can i
Old 01-18-2007 | 09:48 PM
N/A's Avatar
N/A
That really was a "Non" Crotch like response... I was rather impressed at how you refrained. I'm sure you were chomping at the bit, but that took major self control. Consider yourself lucky BrandNEW
Old 01-18-2007 | 10:49 PM
moorport's Avatar
OHH, snap!! I'm so lost I thought I was in the fiddy forum
I do have a Brembo 16 x 18 and a full throttle inc. setup for the f4i for sale though, The brembo is used, the full throttle foot master and line is all new.
JonD
12-21-2015 10:15 AM
zx636minch
01-18-2013 01:23 AM
speedjunkies
01-14-2013 06:55 PM
TUCKNROLLBOY636
01-11-2013 05:52 AM
Quick Reply: Parts to a handbrake....
