polishing the carb
If you look under the caps. You will see a bolt with no head, just a spot to put a flat head screwdriver and a 10mm nut... You have to turn the cam so that the lobes. (Both) are facing down. Once you have done that, you should be able to grab that rocker arm and feel a tiny bit of play. Pull up on it, and place between the top of the valve stem and the bolt going through the rocker arm.. I can not remember right now, but I know MINE was like 8 exh and 10 int?.. Check your manual...
04-05-2017 10:29 AM
