Advice on installing 88cc kit
88-kit tip
When I strapped on my 88 kit,it took forever. All Im saying is, don't forget to re-install the 4-knock pins, blk/gren rubber o-rings,make sure the arrow's pointing down on the head cover,dubble check/remember how to re-install the cam,fly-wheel alighne with cam sprocket, doubbel x 4 on valve/tappet adjustment, use CR8HSA spark-plugs/not CR6HSA...Don't allingh all three piston rings so that thear openings arn't lined up.
sayquan
04-28-2013 11:50 PM
