fork/brake noise? air screw?
hey, I was just out doing wheelies and endos (first time) and after half an hour I heard squeaky noises.. I stopped and took a look at the forks but I didn't notice anything out of place.. any idea what it might be? is it safe to ride?
and the second thing is I tried adjust the air screw a little to see if it would drop the rev's quicker after I gave it gas, but now it's popping a bit if I rev it high.. does anyone know how to properly adjust it, or what the stock settings are? btw, I have a pro circuit pipe and haven't touched my jetting..
thanks
thanks
Air screw
If it's an air screw and it's poping I'd run it in a half turn or so. **** if you have a pipe I'd raise the needle a clip or 2. Should help. I may be wrong on the air screw but I think when you run a air screw in it gets richer. Good luck.
